Контроллер выдает ошибки! Предупреждение — не отрисовано устройство неизвестного типа ap_from при попытке отобразить имя устройства., UniFi Network
Есть идеи, что может вызывать вот это сообщение в контроллере?
[2021-01-22T10:54:13,970] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:54:13,970] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:55:30,992] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:55:30,992] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:55:57,298] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:55:57,298] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:56:15,879] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:56:15,879] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:56:21,914] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:56:21,914] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:56:53,145] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:56:53,145] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:57:26,199] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:57:26,199] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:57:43,576] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:57:43,576] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:57:52,296] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:57:52,296] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:57:56,936] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:57:56,936] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:58:14,517] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:58:14,517] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:58:29,733] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:58:29,733] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
[2021-01-22T10:58:37,836] <inform_stat-1> WARN event - Unrendered device from unknown type ap_from while trying to render device name
[2021-01-22T10:58:37,836] <inform_stat-1> WARN event - Unrendered device from unknown type ap_to while trying to render device name
У меня за последние 3 дня в логах 769 записей с ошибкой "Unrendered device from unknown type ap_from while trying to render device name". Кто-нибудь может объяснить, что это такое?
От участника команды Ubiquiti: https://community.ui.com/questions/Errors-in-server-log-lessinformstat-1greater-WARN-event-Unrendered-device-from-unknown-type-apfrom-/ec8aaa5e-31ed-4011-8edb-6317c1519574#answer/3f1d89b3-71b7-4ad7-bc44-b8c29bff44b5 Эти ошибки можно не учитывать.
У меня полностью пропадает связь с гаджетами и интернетом. Обычно быстренько восстанавливается, но за это время успевает натворить кучу бед. Я недавно обновил контроллер и прошивку, надеясь, что поможет, но нет, стало только хуже. Кто-нибудь уже нашёл, как это исправить?
Пока это не исправлено в контроллере версии 6.2.26, я придумал обходной путь, чтобы игнорировать эти сообщения. Пожалуйста, посмотрите это в другой теме: https://community.ui.com/questions/Unrendered-device-from-unknown-type/82889148-ab9a-4b8b-bb55-bd56e35b2ca6#answer/a378c8ab-9ae5-49ab-8b64-d10b79f3b613
следующее
Я замечаю это на нескольких клиентах UDMP.
следующее
Каждый день я получаю одно и то же предупреждение WARN более 500 раз. Клиенты отключаются каждые 10-15 минут. Перезагрузка любого из восьми моих точек доступа вроде бы решает проблему на пару часов.
Сам заинтересован в решении этой проблемы...
То же самое на UDMB... Событие WARN - Невизуализированное устройство неизвестного типа ap_to при попытке отобразить имя устройства.
У меня то же самое. Устройства и интернет постоянно полностью пропадают. Обычно быстро восстанавливается, но за это время создаёт массу проблем. Недавно обновил контроллер и прошивку, надеялся, что поможет, но не помогло. Скорее наоборот — стало только хуже. Кто-нибудь нашёл решение?
У меня тоже самое.
У меня так же...
У меня так же.
