Unifi AP-AC-PRO: резкие скачки пинга, UniFi Network
Вчера вечером в офисе поставил новый Unifi AP-AC-PRO, надеясь, что он решит проблемы с непостоянным соединением, которые у нас были с обычными роутерами. При 20 подключённых клиентах вижу резкие скачки задержки на Macbook Pro, который пингует наш роутер.
64 bytes from 10.0.0.1: icmp_seq=695 ttl=64 time=1.046 ms
64 bytes from 10.0.0.1: icmp_seq=696 ttl=64 time=2.125 ms
64 bytes from 10.0.0.1: icmp_seq=697 ttl=64 time=2.508 ms
64 bytes from 10.0.0.1: icmp_seq=698 ttl=64 time=1.425 ms
64 bytes from 10.0.0.1: icmp_seq=699 ttl=64 time=1.463 ms
64 bytes from 10.0.0.1: icmp_seq=700 ttl=64 time=2.703 ms
64 bytes from 10.0.0.1: icmp_seq=701 ttl=64 time=1.322 ms
64 bytes from 10.0.0.1: icmp_seq=702 ttl=64 time=2.212 ms
64 bytes from 10.0.0.1: icmp_seq=703 ttl=64 time=1.031 ms
64 bytes from 10.0.0.1: icmp_seq=704 ttl=64 time=1.179 ms
64 bytes from 10.0.0.1: icmp_seq=705 ttl=64 time=1.520 ms
64 bytes from 10.0.0.1: icmp_seq=706 ttl=64 time=22.236 ms
64 bytes from 10.0.0.1: icmp_seq=707 ttl=64 time=5.790 ms
64 bytes from 10.0.0.1: icmp_seq=708 ttl=64 time=1.150 ms
64 bytes from 10.0.0.1: icmp_seq=709 ttl=64 time=0.918 ms
64 bytes from 10.0.0.1: icmp_seq=710 ttl=64 time=2.268 ms
64 bytes from 10.0.0.1: icmp_seq=711 ttl=64 time=5.071 ms
64 bytes from 10.0.0.1: icmp_seq=712 ttl=64 time=2.705 ms
64 bytes from 10.0.0.1: icmp_seq=713 ttl=64 time=2.037 ms
64 bytes from 10.0.0.1: icmp_seq=714 ttl=64 time=1.105 ms
64 bytes from 10.0.0.1: icmp_seq=715 ttl=64 time=1.836 ms
64 bytes from 10.0.0.1: icmp_seq=716 ttl=64 time=1.960 ms
64 bytes from 10.0.0.1: icmp_seq=717 ttl=64 time=2.070 ms
64 bytes from 10.0.0.1: icmp_seq=718 ttl=64 time=1.690 ms
64 bytes from 10.0.0.1: icmp_seq=719 ttl=64 time=7.118 ms
64 bytes from 10.0.0.1: icmp_seq=720 ttl=64 time=5.938 ms
64 bytes from 10.0.0.1: icmp_seq=721 ttl=64 time=1.873 ms
64 bytes from 10.0.0.1: icmp_seq=722 ttl=64 time=1.081 ms
64 bytes from 10.0.0.1: icmp_seq=723 ttl=64 time=1.506 ms
64 bytes from 10.0.0.1: icmp_seq=724 ttl=64 time=1.911 ms
64 bytes from 10.0.0.1: icmp_seq=725 ttl=64 time=2.452 ms
64 bytes from 10.0.0.1: icmp_seq=726 ttl=64 time=1.643 ms
64 bytes from 10.0.0.1: icmp_seq=727 ttl=64 time=1.662 ms
64 bytes from 10.0.0.1: icmp_seq=728 ttl=64 time=2.229 ms
64 bytes from 10.0.0.1: icmp_seq=729 ttl=64 time=1.489 ms
64 bytes from 10.0.0.1: icmp_seq=730 ttl=64 time=1.795 ms
64 bytes from 10.0.0.1: icmp_seq=731 ttl=64 time=1.021 ms
64 bytes from 10.0.0.1: icmp_seq=732 ttl=64 time=1.193 ms
64 bytes from 10.0.0.1: icmp_seq=733 ttl=64 time=1.089 ms
64 bytes from 10.0.0.1: icmp_seq=734 ttl=64 time=1.511 ms
64 bytes from 10.0.0.1: icmp_seq=735 ttl=64 time=128.515 ms
64 bytes from 10.0.0.1: icmp_seq=736 ttl=64 time=110.804 ms
64 bytes from 10.0.0.1: icmp_seq=737 ttl=64 time=4.181 ms
Провёл поиск каналов, выбрал, кажется, самые свободные. Пытался менять мощность передачи — эффекта почти нет, RTT на пингах по всему диапазону только вырос.
На самом деле я столкнулся с этим, используя Remote Play на PS4 Pro. Мой MacBook не справлялся с потоковой передачей. Те же скачки пинга постоянно прерывали весь стрим.
Решения с https://community.ui.com/questions/10e52919-a212-4f4f-a59f-b28820c9479b помогли мне справиться с проблемой.
У меня такая же проблема с Unifi AP PRO на версии 3.9.19.8123.
Ты так и выяснил, в чем была проблема? У меня что-то похожее, но началось это только на прошлой неделе.
У меня похожая проблема. Когда я запускаю шутер от первого лица, мой пинг показывает около 300. Он скачет произвольно: сначала 20, потом 40, потом 150, снова 40, потом 300 и так далее. Обычно пинг прыгает с высокого значения на низкое и обратно. Интересно, может ли настройка UAPSD помочь с этим. Я не эксперт по сетям, но видел на форумах, что некоторые устройства могут не работать с включённой этой функцией. Вообще, не понимаю, в чём дело. Сначала думал, что смена HT 40 на HT 80 и HT 20 на HT 40 решит проблему, но это лишь увеличило скорость, а задержку не изменило. Буду очень благодарен за любую помощь.
